Anycubic P1 Max
Hi :D
Could support for the Anycubic P1 Max be added?
resolution: 11520 × 8640 px
x: 285.500 mm
y: 214.000 mm
z: 300.000 mm
In addition to the standard things both chitubox and anycubics own slicer include a 'calc_layer_volumes.data' file in the pp1m archive (thats the file extension it uses).
That file contains information on how big each layer is (layer number, height, thickness and area covered by the model at that height). This is information the printer appears to use for it's dynamic release feature.
Best regards,
Matthias
Hi Matthias,
I've added the machine profile to our database.
I think it should be able to work.
You are right; they've added a new file in the zip-archive which passes some information about pixels per layer to the printer. Small chance it doesn't work without it;
But if you can give it a quick try as is that would be great? I dont have this particular machine.
I'll add the new file later on; i see it's already on UV Tools github. So the community has reverse engineered it luckily.
