Changing wait before print/lift speed/retract speed depending on layer range
federico 6 Feb 24
hi everyone, i discovered recently this fantastic slicer, before I used Tango slicer.
Formware has every function i need except the possibilities to change some settings based on layer range, that in tango is called "adaptive slice", and it allow to set a printer profile for every layer range that i want (for example from 0-70 layer i can set resin profile A, from that to layer 150 resin profile B and so on, and that is very usefull until the plate is complete out of the resin level.
is possible that a feature like that coulb be implemented ?
thanks
formware 7 Feb 24
Hi Federico,
There is already 'data table' mode for layerheight/exposure. This allows you to set the layerheight and exposure time per layer in any interval.
I think it's a good idea to extrapolate that functionality to have a layerheight based on profiles. And that also includes the speeds and so on. I'll add it to our todo list.
federico 7 Feb 24
Thanks for the reply, different retract speed or wait before lift is crucial for me printing with bigger printer or high viscosity resin, a killer feature should be that the software can calculate automatically from a formula or similar the lift/retract/wait time analyzing the white surface on every layer, that could increase a lot the speed and can optimize the print time.
Unfortunately I cannot use this slicer until I have the possibility of changing the speed and wait time on layer height.
I’ll wait for this feature
Thanks again
