Non persistant command
G
GVDP 9 Apr 24
hi,
When using the "add single support" command (by using icons) the command stays persistent, meaning you can continue positioning several supports while still being in that same command...
however,
When using the "add tree support" the command interrupts each time you finish a tree support, so you need to reclick the icon, each time when you need a new tree support.
When you do hundreds of trees per day, it kinda gets tedious... :slight_smile:
Not sure if it is a bug or an oversight, but i'll report it here anyway...
formware 9 Sep 24
Hi ,
I've rewritten the entire 'display' modes section of the code.
It's more consistent now.
Each support adding mode, will stay in the mode unill ESC is pressed.
It will be release this week.
G
GVDP 17 Sep 24
Elco,
Thank you sooooooo much !!!
This makes my workflow so much smoother and faster.
I really appreciate that Formware takes customer service so serious.
A thousand thumbs up for the team !!
