Saveguard support and print settings?
G
GVDP 4 Jun 24
Is there a way to saveguard support settings to be overwritten?
I noticed that some of my colleagues occasionally overwrite the production settings I've developed for our 3dprint department.
I did save them out as separate files, so i can restore them, but I would like to prevent the settings to be overwritten in the next time I boot up the program.
I'm fine with being able to change values on a case to case basis, but I do not want them to be permanently overwritten so the in next Formware session, you inadvertently start with the wrong settings.
the same applies for the print/resin settings, although there is far less risk there, cause ppl usually do not fiddle with the resin settings
From experience, i know this will end up with a production error, some day...
So it would be good to have the "default" settings protected....
formware 4 Jun 24
Hi GVDP,
So in general not yet.
We do have functionality in there to lock support/print profiles. But this is on a 'machine manufacturer' level. Which our white label clients can do in their backend portal.
If you want you could 'hack' your way in there: in the settings xml you can find a SLocked toggle on the support profiles. (PLocked) for print. Since Formware3d xml's settings are not encrypted you could put these switched to 'true'.
But be aware; this will lock all functionality in the software.. so you can't change the settings yourself either.
A less invasive thing is perhaps to make sure this switch is unchecked:
But please make sure you have this checkbox unchecked:
