Support for Phrozen Sonic Mini?
R
Robert 27 Feb 20
Will there be support for the new Phrozen Sonic Mini? Or can I modify an existing profile to work with the Mini?
Thanks,
Robert
formware 29 Feb 20
Hi Robert,
I will contact phrozen for this.
C
CC3DPrint 24 Mar 20
Hi Elco, any news on support for this printer? The printer currently only reads PHZ files.
formware 4 Apr 20
You can just change the extension to .phz in the output settings.
.phz is just a .zip file.
Info from Phrozen:
if extend filename is “.phz” ==> our machine will be import the run.gcode file and usage it to default resin profile
if extend filename is “.zip” ==> our machine will ignore the run.gcode file . it’s usage our machine build-in resin profile
Z
Zahntechniker 4 May 20
Are you realy sure this works Chitu PHZ is around 5 MB and Formware 206 KB and the printer always says unknown file format ??!! Even a with PZ slicer sliced PHZ doesnt work unknown file format
formware 5 May 20
No this doesn't work.. Sorry seems to be an old topic.
The phrozen sonic mini is a machine that still uses the chitu board implementation. The format has not been implemented as it was closed source and is currently not priority as all other machines (and probably future) machines will use phrozen's own hardware.
