Support for VLARE Open Slicer Format files
fcollingwood 3 Jun 22
Hi Elco @formware
I'm looking at getting a VLARE Core board and 13.6" 7K screen to upgrade my Transform. This board uses an open file format that they are trying to get others to adopt.
You can find further info here: https://www.vlare.net/open-format
Any chance of support in Formware?
formware 3 Jun 22
Yeah sure no problem. Seems an OK format to me. Small effort to include it if it's documented like this.
But is this already the final format? Or when are they shipping boards? ?
fcollingwood 4 Jun 22
Boards are shipping now with the Duobond 6K and 7K screens. It's also in the latest large format Peopoly machine
fcollingwood 25 Jul 22
Hi @formware Elco
Any news on support for this yet? I should be getting my VLARE board and 10.1" 8K screen any day now
formware 27 Jul 22
no no update yet. Doing my best for next release to put it in.
Got the question once more per email so it seems people are starting to receiving boards.
formware 10 Aug 22
Have you by any chance tested the UVTools implementation of this OSF format??
https://github.com/sn4k3/UVtools/blob/master/UVtools.Core/FileFormats/OSFFile.cs
I've checked the description on their website but it leaves room for some interpretation here and there...
fcollingwood 11 Aug 22
No. Ankle surgery has meant that the conversion work hasn't happened yet. I've got another 3 weeks before I'm allowed to walk again.
r
rattus 6 Sep 22
I'm looking at building a similar conversion Epax E10 4K to 8K with Vlare Core board
I can't see either the .vlr file format, or any 8K machines listed as yet
fcollingwood 28 Sep 22
HI Elco @formware
Any progress with this yet? I'll be mobile next week and able to upgrade my Transform, so looking to support and slice with Formware
formware 11 Oct 22
No not yet.. sorry. Incredibly busy with long lists of update points..
Is there any change you can make it work with UVTools in between for the moment?
(I plan to integrate it, but i don't want to hold you up)
fcollingwood 17 Oct 22
@formware unfortunately UVTools outputs broken OSF files.
formware 27 Oct 22
ok thx for the info. Then i know that's not a starting point.
I will do my best writting it in the next few days. It's been encredibly busy with Formnext coming up.
fcollingwood 27 Oct 22
@formware hi Elco. I'm just waiting for some parts for the printer and I'm also away from home currently, so haven't done further testing. I exported a ctb from Formware and converted it to an osf. When I'm back home and the machine is running again, I'll try other formats from Formware, gcode for example, and see if the osf conversions from UVTools works
formware 28 Oct 22
Hi frank,
ok sounds good. I've contacted Vlare for the details on the format. Their website is not updated since 2021 it seems; so before i implement the wrong format..
formware 31 Oct 22
Hi frank,
I wrote an implementation of their format.
I think we might run into some debugging here.. they have some IMHO strange constructs of writing simple binary data.
Also for some parameters it's not clear to me what they do. But perhaps you know. Especially there seem to be even more speed variables than in the latest CTB formats.
https://github.com/vlare3d/OSF/blob/main/src/OsfEncoder.cpp
If you want I can wetransfer you a build when you are ready to test it.
I will also email them some questions regarding the layer format. It looks to me that they use similar encoding as chitubox in the early days. Which is fine. I just have some things unclear; but i think its chinese->english translation.
cheers
fcollingwood 6 Dec 22
Hi Elco @formware
Sorry, I've been a bit tied up. I can run a test for you, no problem.
formware 6 Dec 22
Hi Frank,
I'll double check the format implementation later today and wetransfer you a beta.
J
Jimmygunz 7 Feb 23
Has there been any progress on this? Has Formware included the OSF open source format, or even the VLR? Looking to the same as Fcollingwood, and really like my formware slicer to handle all of my printers.
Please let me know.
Thank you,
James
formware 8 Feb 23
Yes it's in V1093.
But i think Fcollingwood mentioned it doesn't work; however my output is similar as what UVTools outputs; and can also be read by UVTools.
I have my doubts in the OSF format; i think's prone to errors the way they seperated the data of the layers with 2 bytes. The same 2 bytes can occur in any of the layer run length encoded byte data. And this is very dependent on what you are printing.
This makes it very hard to correclty read the file correctly and seperate the layers. I've expressed my concern to Vlare 2 times but have not heard back. I've also asked them how the board reads the file, as that is the only thing that matters in the end. No response.
So i would not buy a vlare board for that reason.
J
Jimmygunz 8 Feb 23
Thank you for your rapid response...
they have stated it works well with their slicer and lychee...
i was planning on upgrading my transforms to a 13.6" 7k mono (as it is exact fit to my mono modded transforms, originally the rgb versions :( ), and from a few things i have read and discussed it says that it will need a vlare board; that the existing control board on the machine doesnt output the resolution...
Maybe you are aware if there is another control board that will play nice/integrate with existing transform components and run the 13.3 7k? I was wondering what control board the Photon M3 Max is using and if that would work? I think it is a chitu board also, friend said it has a different Z height... is there a way to change that? also i havent seen an available touch screen for that unit (not sure if it will work with the existing touchscreen)... from what i understand (at least on the vlare board) was that it was necessary to get a touchscreen to work with the board.
It no prob if you dont know, but figured you have a good understanding of the various machines.
any advice is appreciated/helpful...
Ultimately, I really like Formware and have had it for years... has been great and would love to use it to run all my machines. I advocate for formware whenever it is mentioned; especially due to the perpetual license.. it is a rarity that is done anymore, and it is much appreciated, and shows the dedication to a good product over trying to make as much money as possible.
Thank you!
James
