Text back the front
s
shane160657 25 Feb 24
I have an Elegoo Mars 4 dlp, using the xp matrix validation to dial the exposure in
all the text is back the front, I used the same file with the supplied slicer that Elegoo supply and the text comes out correct, any suggestions
formware 26 Feb 24
Hi shane,
You can setup the flip of the slices in the machine configuration.
There is a flip x and flip y direction.
You can also view the export files by reimporting them over print job import in the menu.
Then you can compare the 2 outputed files and check if they are similar.
elco
