Hi Petr,
I’ve had a look at your sliced files.
I just remember fixing a ‘bug’ 3 weeks ago that existed in PNG and TIFF outputs. Rows of pixels were shifted by 1 pixel in vertical direction of the image. So partially you are right in that the actual output is different. However it has no influence on your print. (well everything is shifted by 1 pixel, but the output should be similar).
Have checked what happens when you re-import the print job in the slicer?
You can do this over menu -> print job -> import (folder or file). (screenshot below of your files).
You can color them as well.
You can then overlay your print job pixels over your model to inspect how it is interpolated.
This way you could see if you agree on what the slicer did in interpolation.
What I notice there is you use a shrinkage corrrection; it seems as if all models are a bit larger sliced then they are in the 3d file. Are you aware of this? (this makes a direct compare on top of the model more difficult)
Wat is the reason you are not using any form of AA? usually it does have a smoothing effect for some part.
Furthermore, if I factor out the 1 pixel shift, i think they are pretty similar on the parts I inspected. Yes there will be some minor differences as summed up earlier.
