As per the title - I’m experiencing lag between mouse input and response on 1.0.3.8
Going to have to go back to 1.0.3.7
Hi Frank,
Not sure what causes that.
Can you check if your crease display is turned of? It’s a known thing I need to fix asap.
It’s turned on, as I can’t see where to place supports otherwise. I only do manual supports
hi,
I’ve wetransfered you an installer where the creases are fixed. I’ll put it online in a day or two.
Looks like it’s working perfectly, thanks for that Elco
Now to try out some of the new features!
I’m still hunting for a final bug (windows inconsistency). Gonna give it another few hours before I release it.
If you want you can send us an email (I don’t know your email) and I can wetransfer you an installer. Otherwise it will be there in 1-2 days.
