I am using Photon mono 4k.
I tried to print with Formware3D, but the print fails from just after the Bottom (7th layer). The resin sticks to both the print bed and the film.
When I print with the same settings in ChituBox, it prints fine.
What I noticed here is that although the print settings are the same, Formware3D seems to move faster and also has a shorter lift distance. I think this is why it is failing to print.
There must be some problem with the printer settings.
Please check.
