- Open F3D,
- load any STL
- click “Add multi level floor structure”
Error:
I have sent report.
EDIT.
OK - Now I have. After uninstalling previour version my config was lost so I restored while XML file. That’s problem. With clear .XML there is no error.
EDIT.
mmm bummer. I thought i ‘prevented’ this exception with a global function. It happens more often when some values are outside the bounds of a numeric textbox. Will check!
Thanks I’ve finally found this one.
It’s most certainly to do with your critical build angle (set to 57 here?)
Then it tries to assign this to a numeric checkbox in the UI that is maximum 50.
I’ve made the code save now for the next update.
In the mean time -> set your critical build angle to 45 degrees max when entering this dialog.
You can set it back afterwards.
