Is it possible to set the maximum preferred angle between the top segment and the pole segment of the support? Specifically, I’d like to have single supports as vertical as possible.
Angle between top segment and pole segment of supports
Currently not setable. Todo.
It’s currently an angle depending on the normal with a maximum.
I can imagine with the introduction of a bigger contact sphere (couple months back) it’s possible to leave the restriction on the face normal direction. Perhaps I can make a bit more logic determining the optimal most vertical angle without interecting the model, but taking into account a bigger contact tip. Would this be a good/safe solution?
