I noticed that near the lowest part of the model the supports are thinner than the taller ones supporting the upper parts, i want all of them to have the same identical thickness, how can i disable this feature?
Auto generated supports random beam thickness
There’s a factor called ‘pole widening factor’.
If you set this to 1 everything will have the same thickness.
