Auto Orientation, approx amt of orientations displayed wrong
If I set the “Approximate amount of orientations tried” to the max value of 324 then exit the program and come back in and go back to auto orientation the slider shows the max value 324 however the slider is not in the 324 position and leaving it there and running the auto orientation is using a lower value.
Expected behaviour: User prior value or display the actual value it’s using instead of the max value that was set but isn’t being used.orientation
Thanks for reporting this. Confirmed and added to the buglist for next release.
In principle all toolboxes are saved when exiting tool (to the software’s memory) and when exiting the software (to the settings.xml file).
Can be this trackbar is not liking it.
