I am sure this is a one off bug that most wont encounter but when generating a contoured base plate support at the default ratio with the “Add model name in border” option checked the base plate is generated in such a way that if you happen to have the lower case letter i in the name of your model it is generated about 10 slices after the border of the base plate support wall has receded. This results in an island wherever there may be a lower case i in the model name.
Easy workaround was to increase the raft wall dimensions. Screenshots attached to better illustrate
