Hello, I’m Fabian ad I’m using this Slicer for some months now, but i noticed a wery big issue.
Maybe somebody or a new update can help me and other people to fix this problem.
The problem is:
When I use the auto-support funktion, the generated supports collide with the object and don’t become red, so I past the most of the time to check the object layer to layer for move the supports that are in contact with the objekt and are not red, see the photo below:
So you can see that only one support is red, but a lot of other supports that are in contact with the objekt are not red, that mean that when I print the objekt i need to true away all why is not possible to remove the supports witouth damage the objekt.
I try to change the format of the file or to use an .stl repair tool, but nothing changed.
So I want to ask at the creator of this slicer, if is possible to check the software for try to fix this issue?
And I have another propose, I don’t know if is a possible thing, but I try to ask and explain what I mean:
Is possible to add a funktion that shows only the red supports?, so is possible to modify only the colliding supports witouth search if there are some.
So a possibility to enable or disable the funktion that shows only red supports. When I enable it, the program hide the jellow supports, when I disable it, the program shows the jellow supports.
Let me know if this is a good idea and if this is possible.
