Can't find .cws export capability for my Monoprice Mini SLA
The Monoprice is supposed to be a clone of the Wanhao D7 (not plus), which is listed as a machine option. The Monoprice Mini SLA isn’t in the machine database. However, at a minimum, the software features page for your product lists .cws export capability (for Creation Workshop) as a feature on your site. I can’t find it. It would make this a heck of a lot easier, as the Monoprice can print the .cws file directly.
A big pre “Thanks!” for anyone that can lend a hand here!
Hi bwanakahuna,
You can set the “job export format” to cws packaging in the machine configuration page under the slice settings tab. Will have a look at adding the Monoprice mini SLA machines to the machine database, it would be great if you could confirm that it works with the cws export format.
Kind regards,
Jan
