Hola, muy buenas, mi consulta es la siguiente, tengo una Anycubic photon, y cuando imprimo, las caras casi verticales me genera un escalonado, y no me deja la cara Lisa.
Tenemos alguna opción para que no ocurra esto?
Muchas gracias!
Capas escaladas en piezas impresas
Thot
If i understand your question correctly you are seeing artifacts on nearly vertical faces.
There is no easy correction for this.
Furthermore; the anycubic photon only allows 1bits per pixel printing. A pixel is either on or off.
That means anti aliasing tricks will not work on this machine as far as i know.
You can try and rotate your part a bit to prevent these artifacts?
