Elco,
There is still the same issue with .CXDLP files for the Creality Halot One printer.
For the Formware 3D sliced file to load correctly, I am:
- Loading the sliced file into UVTOOLS
- Changing the Exposure Time field to the intended value in TENTHS OF A SECOND. so 2.5s = 25 for example. (I think these fields can not be decimals and that’s why they use a 1/10th of a second unit?)
- Exporting to CXDLP V3. since V2 will not work.
This way everything loads correctly in the printer.
Is there a way that you can fix this?
Please let me know if I can help.
Regards
Gonzalo
