Cups and unsupported islands with flexible drainage holes
The cups and unsupported island identification functions in the latest release seems useful, but seem to work only with full boolean drainage holes and not the flexible ones? The flexible drainage holes are marked as unsupported islands, which I guess would be a bug.
Also, the unsupported island identification does not identify all islands, is there a setting to adjust the algorithm? I can provide some screenshots/test file if requested.
/ES
Hi ES,
Yes please provide some screenshots of what you mean!
I will check the flexible drainage holes, good one!
They are treated differently in every algoritm; so probable need to make an exception for these ones.
I sent you a message with some screenshots, hope you’re able to have a look at it.
/ES
