I am new to the slicer but am loving it. I am having an issue with elephant foot problem. Can I get some guidance on what settings to edit to prevent it? Fore reference I am not using any supports, my parts do not need it. They look a lot like a domino. And I am printing them with the small end on the Build plate. They come out great except for the elephant foot problem. I tried undercutting my last parts with a .3x.3mm notch, same issue. Any help would be greatly appreciated.
Elephant Foot settings
bbroyles86
You can use the XYOffset compensation to mitigate the problem.
Set the value for the bottom layers to a negative value; to get smaller cross sections there.
Activate the transition layers if you want it to smooth out over various layers. (it should also be acativated under the movement&exposure tab).
If you want full control, you can also build yourself a formula with the new formula editor.
