Hello Formware team
probably discovered another mistake.
Namely, under the menu Item Print Profiles the specification in the existing profile “50micron default” The setting Slice image format, so I think not right.
in the existing profile stands under slice image format “8 bit png images”
When Wanhao Duplicator 7 of yes has the same LCD 2K screen is in the standard profile but slice image format “32 bit Png Images”
mfg skink
