I’m posting this in the General section because I don’t believe it’s a bug with Formware, per se.
This happens with any model I use to test. I’m using Formware version 1.0.3.9 and I’ve tested with Chitubox 1.9 and 1.9.1.
To cause the issue,
- Slice a model in Formware using the .ctb extension.
- Open file in Chitubox to view layers, detect islands, optionally - delete islands.
- Save using Chitubox.
You will notice that the file size has increase by ~1 KB. This file is now corrupted. It can’t be viewed properly in Chitubox (appears as a block) and the printer will not recognize it. I had this issue when I took my slice file from Formware and loaded it into Chitubox in order to delete minute islands. I don’t recall having this issue in the past. Just curious if you can reproduce this issue and possible explain where the error comes from.
