I used formware 1.2.8
I update formware 1.2.8 to 1.2.9.
Then 1.2.9 crashes at start.
So I downgraded to 1.2.8, it worked before, but it crashes.
I tried 1.2.7, it works. hmm.
And then tried 1.2.8/1.2.9 , crash.
I removed my license using 1.2.7 and moved that to another PC installed 1.2.9.
It worked.
By a reason, I want to use 1.2.9 on the first PC ( it is next to my 3DP. )
I welcome any solutions for this.
I don’t want to re-install windows as much as possible…
WIndows application error event was left as follows
frame work version is the same version with 2PCs.
Application: program.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.EntryPointNotFoundException
at formware_3d.fcode.ui.SiApp.SiOpenWinInitEx(SiOpenDataEx, IntPtr)
at A.c8dcf105c409a9f267e10c66187381510.InitializeSiApp()
at A.c263ef72d4ff1e738bc783c583314503a..ctor(System.Collections.Generic.List`1
