Formware Crash On Startup
Formware crashes on startup, yesterdsay it was running fine, I found this report.wer file in Event Viewer. I am using version 1084. I have re-installed .net framework but this issue still happening.
crashreport.zip (3.7 KB)
Hi Taylan,
I can’t deduce anything from this error report.
If you get a hard crash it’s usually something with the graphics drivers.
did you happen to update any graphics drivers?
Can you check what happens if you remove yoru settings file? (small chance… but prehaps… it’s in the roaming folder)
elco
Cool, It worked! Thank you.
