If there is an error the hourglass cursor seems stuck on sometimes. A few times it came up for apparently no reason. Clicking on any button makes it go away and the default cursor return.
Hourglass cursor stays too long
mm. Not sure what to do here
It might be windows itself that will force it if the UI is stuck.
Might also be there is a loop still running in the background…
2 Notable algoritms that might get stuck (still) are:
- base plate with custom contour
- nesting with irregular shapes
Both require an exact contour of the object to be generated; and somehow not 100% watertight all the time.
tasrgi
I was not actually performing any functions at the time. New computer so I will check for issues at my end.
Thanks.
