Hello
I try to export from rhino 3 pieces in different layers but formware threat it as one.
When I select one of it all 3 are yellow highlighted.
Is there a way to import separate pieces from one OBJ file
Thanks in advance
Import separate pieces as obj?
MIGUEL
Other option is to do ‘splitdisjointmesh’ command in Formware. It works similar as in Rhino.
Splits connected topology of the mesh. Assuming the mesh is valid
MIGUEL
HI Elco
It works great, I have imported this 3 pieces as one OBJ and applying “splitdisjointmesh” I can threat each piece separately.
Thanks!
Soon I will post a print
