Infill is not working
i was trying to generate infill within an hollow cube with 1.5mm Walls and 100mm sidelengh.
The Software pretends to create the infill, but the cube is still empty.
Christian
Did you have holes?
Infill is only added in complety inverted shells.
Otherwise there is no really inside…
Solution is to first infill; then add holes.
No there are no holes.
To test this i took a cube with 100mm side length and created a hollow with 1,5mm wall thickness and then tried to add infill. The result is as shown in this picture.
Christian
Thanks. Bug confirmed.
The hollowing algoritm generated some unique degenerate faces that all algoritms didn’t cache.
An example is a face with all 3 vertices on 1 line.
Result is the volume of the shell inside can’t be calculated correctly…
I’ve fixed it but can’t release at the moment cause i’m working on some bigger updates.
Hope end of this week to release a new version.
Thanks for this Feedback. Please Keep me update regarding the new Version.
Christian
