Infill No Closed Inside Shell
I’m using the trial version to see if I like FormWare. I’m trying to add internal infill, however no matter what model I pull in that work fine in other software, FormWare always says that there is no closed inside shell found to create infill.
Any ideas?
Hi mdiorio,
Did you use the hollow function first?
Booleaned drainage holes can also cause issues; there is no difference between inside and outside.
So workflow is: hollow, infill, drainage holes.
