Objects that are mirror copied in the X or Y direction are not sliced correctly. Is this a bug? Or is there some setting?
Mirror copied objects cannot be sliced.
ViperZ
J.Verschoor
Hi ViperZ,
Sorry I diddn’t see that I had to approve your post earlier.
I tried to recreate this, and did notice a bug with slicing mirrored objects, but only if CPU slicing is enabled.
Will fix this in next release, until then could you switch your machine to GPU slicing?
Configuration > your machine > slice setup tab > untick force slice generation on CPU
Kind regards,
Jan
