The “file name in baseplate” function isn’t working on 1.0.4.3
all shapes and offsets still produce the name hanging off the plate
Model on baseplate bug
shane160657
mm i’ll check it. Seems the letters should be a little higher when the base plate is not hollow.
The floating part is an underscore??
shane160657
The base plate is .6mm thick and the floating sections can be removed by getting rid of the under scores in the file name (Zbrush names the files that way), thats probably the best solution at the moment
