hello
1.
I have some questions about “Off time between layers” and “Off time between layers bottom”.
I asume that the “offtime between layers” means the layers after we have reached the last base - or bottom layers and the “off time between layers bottom” only refers to the first 6-10 layers I want to expose with a higher time value.
Is that right?
2.
If I put in following values:
Z Lift Distance 6mm
Z Lift speed 80mm/min / 4,6 s
z Retrac speed 160mm/min / 2,3 s
total up and down / 6,9 s
oftime between layers 12s
it means that I have 5,1 sec without projecting light before the plate lift up again?
Im right???
What could be a reasonable Time for "Phrozen Wax-like Violet Castable Resin"to seattle down and cool a little bit the LCD
Thanks in advance, Mig
