Override decimals not working in Support Generation (Advanced)
I set override decimals to 2 in General Settigns. Works in other menus but not in the Auto Support Generation (advanced) tabs. For example Tip Beam Diameter set to 0.45 will always revert to 0.5 mm. Using v1058 but never tested in earlier versions so I don’t know if it’s an old bug or new.
Hi Chris,
No it’s a problem that was always there.
I’m currently re-doing the last part of the UI controls. The entire tool interfaces will become automatically generated instead of manully designed as now. This will make the entire process much more error proof.
(It grew a big to large to design manually… )
