Phenom NOIR / Error on CTB export
Hallo.
I am using a Peopoly Phenom NOIR. Normally i export as CDBDLP (V2). This works well. Now i tried to change export to CTB and the following error occurs:
I am using a new PC with a GTX 1650 graphics card etc.
Do you have any idea? I need to change the file format, because the CDBDLP-files are too big.
Thanks.
Hard to tell what is going wrong. This is usually an error related to PNG writting.
Can you send me your settings.xml file over our info@ email? (file menu -> export)
I could check what is going wrong there…
Hi Danner,
We found the bug that causes this error, it has been patched in the latest release.
Cheers,
Jan
