I’m trying to use the “split movement” option on a photon mono 4k but the printer is only using the first phase of movement (the slower one).
Is there limitation or something not supported on the photon mono?
Thanks
Thanks
Out of the top of my head I don’t think it works on the mono 4k.
You can check in photonworkshop if the ‘advanced’ setup is enabled in the settings of the machine.
