Phrozen Sonic XL 4K 2022 not printing
Received new XL 4k 2022, when I transfer file and start printing, the platform mooves just few mm around the Z axis sensor and then it displays “waiting printing” on LCD and nothing happens. Using the provided “DS Slicer” works. So probably wrong files are generated for the printer. Any idea what can I do to fix the problem? Thank you. Petr
Hi Petr,
I’m not sure what is happening there. I will forward it to phrozen.
They manage their own print profiles/machine profile in our portal.
Hi, Just debugged little bit more. This problem is only when I select print profile manualy in printer, otherwise it is working fine with “RUN G CODE” So probably printer FW bug, not related to formware
