Phrozen Transform won't run the G-code
Hey,
It looks like the Phrozen Transform will not run the G-code generated by FormWare3D.
I’ve tried to vary the first layer exposure and other settings and it is not working when I try to print.
The printer defaults to it’s built-in profile instead.
Could it be that it needs to be exported in .phz for it to recognize the G-code?
Yes. For the older phrozen machines you can change the .zip into .phz (it’s a setting in the machine slice setup)
.zip or .phz determines which gcode it takes.
