Hi all,
I’m having some issues with the software as of late. Software performance has slowed considerably since first downloading and using, and there are miscellaneous errors that are popping up. See below
- Slices will stop or hang (often leading to a soft or hard crash of the software)
- Support material will generate only around the edge of models
- Infill will not generate
- Drainage holes do not generate plugs (I’ve ensured that “create drainage plug” is selected)
I’m not sure what to make of it. It feels like a cache problem perhaps? The issues pop up on different files, all have been run through the repair engine. I’m rather new to the software so I’m not sure how to go about solving this issue.
Specifications:
Dell Precision T7910
Xeon E5-2603 v3
32GB ECC RAM
Windows 10 Pro build 19042.630 (20H2)
AMD Radeon Pro W7100
Formware v. 1.0.3.4
Peopoly Phenom L
