Problems of cutting, Saturn 16k, GPU cutting
I apologize in advance, I am writing through a translator.
  1. I print quite large, heavy files and often encounter defects, FORMWARE has proven itself much better than other slicers and literally saved my printing, but still often get unstable results, could this be because my GPU does not work, and on different PCs, and the slice goes through the CPU? How can I generally improve the quality of files for printing.
  2. I would really like to get a profile for Saturn 16k, are there any plans?
Sorry for the delayed reply; somehow I didn’t get a notification for a message.
Since a couple of years the slicing all works on the CPU. GPU’s in general struggle from the time it takes to get the data on the GPU and back.
I would first make sure your model is repaired (repair command) and contains no defects.
I’ll make a round across the new printers in the next weeks. But you can also add a machine yourself in the configuration if you know the export format. Do you know what format it requires?
