The behavior of scaling is a little odd for me. Could you please elaborate on how you expect scaling to work?
For example, when scaling a model (then finishing whatever work you were doing) and then loading a new model, the scaling value is still what it was on the previous model. So, when you loaded the new model, is the new model now scaled to the scaling value or is it the original size?
Or, if you scale a model, the program applies that scale to the model (as expected). But if you re-enter the scale module, the program seems to repeat the scaling of the model (ie: say 50% of a model already scaled by 50%, and so on). I would have expected that you would enter 0.5 for the initial scaling. If you wanted half of that again, you would enter 0.25.
How have you programmed scaling to work?
Thanks,
Robert
