Selecting supports
I appreciate the control available in manual supports, but I’m frustrated with trying to delect them if I want to delete them.
So - How do you select an etire support rather than just an element of it? I know you can lasso them (Shift L click and drag), but this isn’t always convenient. Both right and left click select an element. Would be great if left click selected and element and R selected the entire support.
to delete a support at once: select a piece of it. (i.e. 1 beam) and then press ctrl + del
that deletes the entire support.
i see if i can make it as you describe that right click selects the entire support. Thanks for the suggestion
I just tried that Select any part, Ctrl+Del and it deletes all autogenerated supports, Vers 1.0.2.9 Win 10
Gary
