I don’t like chicken pox. I don’t like post work. I don’t like sanding, I don’t like filing, I don’t like filling, I don’t like overhangs that look like melted poo.
I like to place single supports, then move them off the model so that my overhangs are clean without messing up my model. The latest version of Formware does not attach the tip to the model.
The ball needs to stick to the model where I put it, and the base needs to move where I want it. Also of note, the cylinder that Formware creates for the support does not auto-clip to the base. I tried moving things far out and it said “There are parts or supports below the build table”
As currently written, Formware will allow you to parametrically increase the size of the contact ball, parametrically allow you to move the knuckle but the only way to move the base without moving the whole support is to move the knuckle first and hope. Here’s what happens if you move the knuckle and then grab the base:
Tip movement mirrors base movement, rather than staying attached.
I’m dead in the water again until this is fixed. Please take a look, Elco.
Thanks,
Seth
