This seems pretty inefficient. It’s also very slow.
(its also barely touching the GPU but im apparently only allowed one file)
win10, ryzen3650x, 2080ti
It depends on what you are doing.
Which machine?
What settings? (especially thinks like low end machine that require some special run length encoding to work or slice offset corrections can slow things down)
Which slice engine are you using? CPU or GPU?
(check the machine settings -> slice setup tab, is force CPU checked?
