Hello everybody,
I have a problem, I create all the supports on the models on the built plate, I check all the layers then I slice. After slicing some models are not in z=0 in the preview of phrozen. I check in formware an the models up of one layer.
Can you help me to fix this bug, it make me crazy !!
Thanks a lot
Slicing problem on sonic xl 4k
Digilab
kuebelkiller
Hello
For me this bug happens as well - but only when there are some supports not “long enough”.
For example:
I put the part 2,8mm above the build plate - then this bug happens
but when I put the part 3,0mm bove the build plate with supports below, the bug does not happen anymore.
Best regards, Chris
Or if possible a sample printjob that yields the problem. (Can we send to our info [a]t email address)
thx
And perhaps which version are you using? (help menu -> about)
And are you using a CPU slicing profile? (configuration -> machine slice setup tab)
