Hi, is there a way to set a “minimum distance” between the part and the supports ? like in lychee slicer for example. Because I end up with supports that cannot be removed because they are too close to the piece and become part of it.
Support distance to the model
Yes, the variable is called ‘first beam length’.
Assuming you are using auto supports:
