I think this issue may be related to the “Single Supports are Broken” Bug reported by Trillum in December.
It is very easy to reproduce
To recreate the issue:
Start a brand new File and import in a square “Test” Cube. (the exact file doesn’t matter, as long as the object’s bottom is perfectly flat and parallel to the build surface.
Move the Cube up off the Build Surface
Attach a single support to the bottom surface anywhere inboard of the edges
Switch to Edit Support mode, and select the support in the middle - Below the “Joint” but above the “Foot”:
Now drag the support. Notice that the entire support, including the tip move. I would expect the tip to stay anchored to the Model
To create the expected behavior:
Create a brand new file and import the same “Test Cube”
Move the Test Cube up off the Build Surface
Now Rotate the Bottom of the Cube .01 degrees (the angel doesn’t matter, you just need to remove the parallel condition).
Switch to Edit Support mode, and select the support in the middle (Below the “Joint” but above the “Foot”
Now drag the support. The Foot and Support move, but the Tip stays anchored to the Model. Note there is a “False” Interference warning at the Tip, but at least things work as expected:
Note That Rotating the model 10 degrees takes care to the “False” Red Interference warning:
