I cannot find a setting that avoids the creation of very short supports near the build plate extending under the build plate. It happens when added manually. This problem does not happen during automated support generation. different supports are generated when they are very short. I am trying to rest the model on the build plate to save print time and money, hence very short supports are often required.
There were comments about this many, many months ago, Q1 2019. Please would you advise how or when this problem can be fixed?
Trying to use the tick box fix accidental penetration below zero when using internal supports even when there were no obvious penetrations of the plate caused the whole support lattice to shift x++ - this was after flattening supports.
Thanks
