This one took some days to trace the origin…
Since last week we started getting a very thin film that extended from the base layers towards the edges of the buildplate on our Anycubic Mono X.
trying to find where the sudden cause could be , i did some online research on the possible causes of such a strange phenomena.
possible causes :
-frozen liquid resin damage
-too high UV intensity
-not level of the buildplate
-over exposure+bleeding
-defective USB
-software bug
-failing LCD screen
I’ve tackled all individual possible causes one by one, and in the end i was left with the software bug as last remaining.(apart from replacing the LCD screen)
-replaced resin completly : no difference
-reduced UV intensity: slighlty better, but still a thin film
-releveled buildplate : no difference
-reduced exposure times : failed print, so obviously i’m at the edge there
-swapped usb stick : still thin film
-exported slice file from v1145 instead of v1176, and behold : NO FILM !!!
I did a comparative between exports from both v1145/v1176, and both files have the same size…
I got the idea of a “software bug” because since last week, we did start using v1176 in production, about the same time the issues started. Just to big of a coincidence there? We’re running 2 licenses of which only 1 was upgraded to v1176.
To find the possible cause I eventually did use v1145 on the other system to print a few samples and found no issues…
To put it further to the test, I reprinted on the other pc with v1176 and got the dreaded thin film again…
Must say I’m baffled on what can cause such a behavior. I hope you have an idea to what the cause can be…
We can still continue to use v1145, so that we do not have to do vat-cleaning after each print
A wild idea, but it almost seems that, for some reason , the black is not 100% black anymore and lets a small amount of UV light slip through, resulting in a thin film.
I’ll upload a picture of that thin film later…
Anything you need to start digging into this?
