Updated to V 1.1.9.5
Something has caused the auto generate support to take much longer to complete.
Support profile 1.
Density is 101% should it be this high?
DaveH
Hi Dave,
Hard to tell. We haven’t made significant changes there.
Are you able to email/wetransfer us an example file so we can check?
Density is inversely related to support point distance. You can use either density (historically there) or just an absolute point value. (user request later on)
The tip diameter is also taken into account in this relationship. If you want I can dig it out of the code… what the relation is.
DaveH
After the upgrade, 104% took over 5 mins to complete, the supports were a solid mass. I reduced density to 5% and auto-generated, then back to 123%, this seems to have corrected the problem.
