As it is now, all existing supports are cleared/removed when you apply autosupports.
However, my support strategy is one of heavy ankerpoints + fill autosupports.
The use of achorpoints is needed when you work with very high viscosity resins.
As it is now, i need to add achorpoints AFTER applying autosupports, which makes it harder to see their placement.
I would like to see a toggle option to allow existing supports to remain in place, while applying autosupports. That way , it is possible to precisely position the achor points and then flood fill with autosupports to ensure general support.
